Providing the correct amount of water and nutrients to the plant is crucial. Too much water and the plant dies, too little water and the plant dies. For that reason, I will let the plant decide. I placed a liquid level sensor in the planter. When the water level gets low the sensor will tell the Arduino to turn on the water pump. This sensor was found on Adafruit.
https://www.adafruit.com/product/464
Frank Vigilante
