• Components Are On
    Frank Vigilante • 04/02/2015 at 03:46 • 0 comments
    I had to put it in the Solder Oven twice, and it took some work afterwords with the hot air gun, but I was able to get all necessary components soldered on the Prouino (remind me never to go lower than an 0805 package again). Just need to run it under the microscope to make sure there are no issues.
    One of the reasons I am excited about the Prouino is because it will come with a LiPo battery attached, and will be rechargeable via USB cable.
    For those wondering, the circuit board measures 36x36mm.
  • Component Day
    Frank Vigilante • 04/01/2015 at 18:48 • 0 comments
    All components for the Prouino have arrived. Today we test out our Soldering Oven (http://hackaday.io/project/5044-100-toaster-hack), and hopefully get the Arduino bootloader flashed into the first chip...stay tuned.
