Back where I started
A project log for Cruise Control Preset
This project supplements the existing cruise control in a vehicle, allowing you to automatically set the cruise control to a selected speed.
scott-hammerschmidtScott Hammerschmidt • 05/15/2015 at 19:19•0 Comments
I made the quick changes to display '65' on the display and programmed that up. Looks pretty much like what it did when I was using the Arduino IDE:
Ah, but now it's being built and programmed in Atmel Studio! :)
I spent a little time looking at the GPS parsing. I did find this project that is a library for parsing the NMEA sentences the GPS spits out. I might end up rewriting it in C, but it seems like it would work well. The use of floating point numbers bothers me a bit, I don't know if I will (or can) stick with those.
Next up, doing something other than trying to display '65'. :)
