FireBoxRoom Scraper
These scripts are meant to make the lives of Metaverse explorers and developers better while helping to decentralize the Metaverse by archiving assets to the Interplanetary Filesystem. While exploring the immersive web using JanusVR, pressing Ctrl+S will copy the source code of the site you are currently on (as well as download the html/json file to your workspace folder) to the clipboard.
One line to brute download assets in a FireBoxRoom with absolute paths. This requires the package 'wget' to be installed, otherwise you can chop off the part '&& wget -i assets.txt' and just have the assets.txt file serve as a list of absolute links found in the file.
cat index.html | grep -Eo "(http|https)://[a-zA-Z0-9./?=_-]*" | sort | uniq > assets.txt && wget -i assets.txt
I wrote a script using python3 to more politely index and count
the various assets in a given FireBoxRoom and optionally download them
separately or all at once. https://gitlab.com/alusion/fbparser
alusion
