This was a crude prototype for testing and proof of concept. Which has demonstrated there is significant energy available from a solar panel to cool over 20 litres of liquid well below -4C in less than 6 hours using off-the-shelf peltier coolers. Further that liquids can be stored over 48 hours and used later to dehumidify air when conditions are best and collect water for drinking. Cooling could be significantly improved using a compressor refrigerator unit with better energy efficiency but at a greater cost. Dehumidifying the air could be significantly improved with better vessel and distillation coil design. The system could be scaled up or scaled down. Coolant storage is not required if batteries are used but this also comes at greater cost. The system could be run while the sun shines if sufficient humidity is available and the dehumidifer vessel is appropriately insulated.
