Form Fitting - Putting the Straps (Day 2 - Afternoon)
A project log for DIY Prosthetic Socket
Human Machine Interface (Arm)
atharvshringaregtatharvshringaregt 02/13/2018 at 12:280 Comments
To continue on the path that we left yesterday, that is to improve the form-fitting of the prosthetic. After lunch we started working on this problem.
We started by brainstorming some ideas for how to fix the problem.
The use of straps was concluded from the discussion. We interviewed the end user on where the straps should be attached.
We also had to refine and add to the existing prototype to implement the straps more efficiently.
Then we finally had the straps attached to both the prototypes as required.
