The end goal for the Autodro is a complete monitoring system for under $10. This means that cheaper, simpler, less accurate sensors are needed. I've started with a simple EC sensor, and am hoping to design something around $1.
So far, I've created a sensor using a Wheatstone bridge, and have ordered a PCB from OSHPark.
Tim Butram
