I built the base cabinet first, and left the backbox for later.
The first part of building the cabinet was sawing the sides to shape (with my favorite tool, the Japan saw.
Next, drilling holes for the buttons and plunger:
The corners are held by the leg brackets. The back brackets are turned upside down so that the front legs are attached higher on the cabinet than the rear legs. This makes them shorter, and the entire cabinet tilted a bit towards the player.
I glued in triangular wooden pieces behind the leg brackets to make it easier to drill the holes for the leg bolts later. They are not visible in these photos.
I hoped that I had calculated the dimensions properly, and I had!This is what the cabinet looked like from the back:I had to give it the first test run in the cabinet:This assembly only took two to three days - I had the pieces home on January 17, and did the first test on January 19. It really felt like the project was moving along quickly now, especially after spending a month planning, doing Sketchup work and buying second hand components.
