It's purple now
04/08/2015 at 13:18 • 0 commentsBoard, stencils and parts ordered
RATSNEST: NOTHING TO DO
04/07/2015 at 22:23 • 0 commentsAlright, that was annoying. Here's the full board:
Despite getting the shift register/LED driver thingy right, this was a farily annoying board to route. For exhibit one, I present something from the Sparkfun Eagle library:
Genius.
Now that this is done, I'm going to run the DCR, sleep on it, check it again in the morning, and send it off to OSHPark. It's ~$45 without a stencil, so not too bad. The total BOM cost of this clock is looking like it's going to end up somewhere around $200. Oh well.
This layout could not have gone more beautifully
04/07/2015 at 15:15 • 0 commentsYou would expect laying out a board with an RGB seven-segment display would be horrible, right? Nope:
That's an ST LED2472G 24-channel LED driver sitting right underneath the RGB seven-segment LED. That's also a lot of planning to get all the LEDs connected to the driver without any vias or other horrible layout bullshit.
Here's the full view of the board so far:
The size is loosly based off a Raspberry Pi hat. There's a DS3231 RTC on there, four of the segment displays, and two 5mm RGB LEDs for the seconds colon thing.Now that the LEDs are laid out, the only thing left to do is to connect the data, clock, latch, and OE lines to the Raspi header. Then it's off to OSH Park for rush shipping, and about two weeks of waiting.
