Hackaday.io Hackaday.io
Sign up Log in
Stargate Atlantis Scanner Remote
An universal Remote inspired by the live signs scanner from Stargate Atlantis.
andreas-hoelldorferAndreas Hoelldorfer
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
8.1k views
7 comments
144 followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
8.1k
7
144
18
Team (3)
  • andreas-hoelldorferAndreas Hoelldorfer
  • chaotinchaotin
  • dunkelsterndunkelstern
Join this project's team
completed project
sci-fi-contest
Related lists
Infrared and Universal Remote Projects
Projects that control your TV, stereo, and more
This project was created on 03/17/2014 and last updated 12 years ago.
Description
The design is based on the series
http://www.gateworld.net/wiki/Ancient_scanner
main features are:
- IR receiver and sender
- 3,2" touchscreen
- Qi- wireless charging
I abandon this project a wile ago.
As requested here are the stl files:
http://www.thingiverse.com/thing:644662
Components
  • 1 × LeafLabs Maple Microcontroller Board http://leaflabs.com/devices/maple/
  • 1 × 3,2" TFT LCD Arduino Shield
  • 1 × Qi Wireless Charging receiver
  • 1 × sparkfun Blackberry Trackballer Breakout Blackberry Trackballer Breakout
  • 1 × BMA020 Digital, triaxal acceleration sensor
Project Logs
Collapse
  • Cad files for download
    Andreas Hoelldorfer • 01/20/2015 at 22:35 • 0 comments
  • Project closed
    Andreas Hoelldorfer • 01/08/2015 at 22:48 • 1 comment
    I close this project, because I've no time and motivation do finish it.
  • Problems
    Andreas Hoelldorfer • 04/24/2014 at 19:52 • 0 comments
    Well this project started a wile ago, at this time I was locking for an Ardino compatible battery powered board with a little more power. I fond the LeafLabs Maple Board with an STM32 ARM microcontroller with an integrated LiPo charger. Unfortunately the pin mapping is not ideal to match the TFT so I have to sort bits for every output byte witch eats up the hole more performance of the Arm chip. Another point the battery controller is not able to switch on the fly between battery and cable power and no automatic charge.
    Further there are not enough I/O pins for all my periphery.
    My solution is to build a hole new motherboard but this will tank much time and other projects are higher on the to do list.
  • Printed first version of the case
    Andreas Hoelldorfer • 04/23/2014 at 15:02 • 0 comments
    I printed the first part of the case, to get the components in place
    https://plus.google.com/photos/111510669637026758430/albums/6005503218372700161?authkey=CJ6z-7KI7OT2lwE
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
TheotherMike wrote 12/29/2014 at 14:24 • point
Hi, still working on this?? Would be great to see your updates...!
Swiftclaw wrote 04/26/2014 at 13:14 • point
I love the idea ! Are you planning to give the 3D model file of the case ? I would like to make one for myself.
Andreas Hoelldorfer wrote 04/26/2014 at 20:40 • point
I will put them to download . Buts not ready to publish.
TheotherMike wrote 04/21/2014 at 09:49 • point
Hi, any updates on this? :-)
Andreas Hoelldorfer wrote 04/23/2014 at 13:04 • point
Good news is project is not dead, still working on it.
Bad news, it will not be finished to the end of April.
Eric Evenchick wrote 03/17/2014 at 21:51 • point
Do you plan to 3D print that case? That'd be one way to give this a very authentic look.
Also, any plans for what to do with IR? Awesome TV remote? Ancient TV-B-Gone?
Andreas Hoelldorfer wrote 03/17/2014 at 22:00 • point
yea, we currently working on the case.
I'm thinking about a universal remote to control TV, and multimedia equipment.
another idea is to add bluetooth or other 2,5GHz communication to make a wireless mouse and keyboard.
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Stargate Atlantis Scanner Remote", please tell us the reason.
Send message
Remove Member
