Hackaday.io Hackaday.io
Sign up Log in
Nova Blinky
Nova Blinky is a single-board microcontroller system designed by, and for, The Nova Labs maker space in Reston, Virginia.
cogwheel-circuitworksCogwheel Circuitworks
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
843 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
285
0
843
5
Team (1)
  • cogwheel-circuitworksCogwheel Circuitworks
Join this project's team
hardware
completed project
arduino ATMega32u4 blinky
Related lists
Atmel® AVR® Projects
Atmel® AVR® 8- and 32-bit MCUs deliver a unique combination of performance, power efficiency and design flexibility.
This project was created on 04/09/2015 and last updated 6 years ago.
Description
Nova Blinky is a single-board microcontroller system designed by, and for, The Nova Labs maker space in Reston, Virginia. It is designed to be used in introductory hardware and sofware classes.
It uses an Atmel ATMega 32u4 processor. It looks like an Arduino Leonardo to the Arduino IDE software. Simply connect the USB interface to a PC and set the board type to "Leonardo".
In addition to all I/O bring brought out to prototyping headers, it has 12 LEDs arranged as a clockface, and two buttons, allowing students to immediately learn about basic input and output (I/O) programming concepts with no additional hardware.
All doc is up @ https://github.com/NovaBlinky/
Project Logs
Collapse
  • First Run of 25
    Cogwheel Circuitworks • 04/09/2015 at 01:31 • 0 comments
    A trial batch of 25 blinkies were circulated around www.nova-labs.org .. Reception was good, and there are 3 classes wishing to integrate it..
View project log
Log In/Sign up to comment
Sign up with Github
OR
An Arduino-based variant that brings a slightly smaller footprint and two shield sizes to choose from.
Project Owner Contributor
Solstice Design System
maehemmaehem
A simple guide for getting to know your Seeeduino v4.2 better, and to prepare your board for use with the Arduino interfaces.
Seeeduino v4.2 Setup
electorialsElectorials
BEETLE has a small size and use the leonardo microcontroller as the brain. This is very small, compatible and easy to carry microcontroller.
SMALLEST Arduino DEV Board EVER!
lithium-ionLithium ION
Arduino UNO compatible with GVS connections
GVSDuino
land-boardscomland-boards.com
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Nova Blinky", please tell us the reason.
Send message
Remove Member
