Hackaday.io Hackaday.io
Sign up Log in
Nova Blinky
Nova Blinky is a single-board microcontroller system designed by, and for, The Nova Labs maker space in Reston, Virginia.
cogwheel-circuitworksCogwheel Circuitworks
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
842 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
467
0
842
5
Team (1)
  • cogwheel-circuitworksCogwheel Circuitworks
Join this project's team
hardware
completed project
arduino ATMega32u4 blinky
Related lists
Atmel® AVR® Projects
Atmel® AVR® 8- and 32-bit MCUs deliver a unique combination of performance, power efficiency and design flexibility.
This project was created on 04/09/2015 and last updated 7 years ago.
Description
Nova Blinky is a single-board microcontroller system designed by, and for, The Nova Labs maker space in Reston, Virginia. It is designed to be used in introductory hardware and sofware classes.
It uses an Atmel ATMega 32u4 processor. It looks like an Arduino Leonardo to the Arduino IDE software. Simply connect the USB interface to a PC and set the board type to "Leonardo".
In addition to all I/O bring brought out to prototyping headers, it has 12 LEDs arranged as a clockface, and two buttons, allowing students to immediately learn about basic input and output (I/O) programming concepts with no additional hardware.
All doc is up @ https://github.com/NovaBlinky/
Project Logs
Collapse
  • First Run of 25
    Cogwheel Circuitworks • 04/09/2015 at 01:31 • 0 comments
    A trial batch of 25 blinkies were circulated around www.nova-labs.org .. Reception was good, and there are 3 classes wishing to integrate it..
View project log
Log In/Sign up to comment
Sign up with Github
OR
BEETLE has a small size and use the leonardo microcontroller as the brain. This is very small, compatible and easy to carry microcontroller.
Project Owner Contributor
SMALLEST Arduino DEV Board EVER!
lithium-ionLithium ION
A straight-forward tutorial on how to properly get the Maker Uno ready to work with Arduino-compatible software and hardware.
Maker Uno Setup
electorialsElectorials
Tiny Breakout Board for CH551G/CH552G/CH554G 8-bit MCUs
CH55xG Tiny
sdtelectronicsSdtElectronics
Tndunio Mini is a similar Arduino function of uno development board, but with the world's smallest size: 15*18mm, it is only 1/13.5 UNO of t
Tnduino mini-----The small and small
watchzhongwatchzhong
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Nova Blinky", please tell us the reason.
Send message
Remove Member
