Today we are working on finishing our automatic tape feeders, and they should be completed today. Also, we are changing some things to make the CV work faster, and should be done today as well. The next thing we will be working on is the placement of IC's.
The next video posted will most likely be of us producing one of our Arduino RTD Shields seen here http://www.protovoltaics.com/arduino-rtd-shield/ To populate the Arduino will require two head changes for each of the two IC components on the board. The starting head will place the 0603 components.
No time frame has been set for this "to do list." We aren't sure how much extra programming will need to go into the CV to place the IC's, but we have a general idea of what we think will work. We will keep you updated throughout the process.
