External Antenna
A project log for ESP8266 (ESP-07/12) Dev Board
PCB for fast development with ESP-07 / ESP-12 with on board USB to Serial converter and on board lipo charge / protection circuit
alexAlex • 06/01/2015 at 13:45•0 Comments
You may have wondered where for this slot on the PCB is. Here is the answer: You can solder a small piece of PCB into it to get a mount for an external antenna:
