Error on the rev2 PCB!
A project log for ESP8266 (ESP-07/12) Dev Board
PCB for fast development with ESP-07 / ESP-12 with on board USB to Serial converter and on board lipo charge / protection circuit
alexAlex 07/25/2015 at 20:500 Comments
sadly I made an mistake while designing the PCBs. There is a missing wire:
But this does only affect the RX, TX and Power LED so if you are not using any of these LEDs you do not have to worry. The PCBs do work without any modification. If you need the LEDs get a screwdriver and a soldering iron and fix it like this:
So I did fix it on both boards I soldered so far. It is not difficult. Tomorrow I will post pictures of the finished board in their nice acrylic cases. They do look good.
