REV 2.1 PCB update and micro USB
A project log for ESP8266 (ESP-07/12) Dev Board
PCB for fast development with ESP-07 / ESP-12 with on board USB to Serial converter and on board lipo charge / protection circuit
alexAlex • 08/25/2015 at 14:10•0 Comments
So with this I fix (I hop all) issues of rev2.0 . I also added support for micro USB. So an micro OR mini USB connector can be used now. Not both at the same tme, because they are mounted at the same place.
You can fin the Gerber files in the Bitbucked repository. I will not order rev2.1 board fore myself yet. First I do have enough of rev2.0 and I will add other stuff before I do order a new revision.
[rendering of the Gerber files made with Viewplot 2.0]
