rev2.2 layout ready
A project log for ESP8266 (ESP-07/12) Dev Board
PCB for fast development with ESP-07 / ESP-12 with on board USB to Serial converter and on board lipo charge / protection circuit
alexAlex • 10/24/2015 at 20:03•0 Comments
I did finalize rev2.2. Because I'm nearly out of boards. I think I will also order this board soon. Main improvements over rev2.0:
- header for external serial adapter
- power rails
- optional compatible to the node-mcu boards
- mini or micro USB
As soon as I ordered the boards you will also find the gerber files in the bitbucket. This time I will try some Chinese manufacturer outside of dirtypcbs. An the board will be green (like in the render).
