I've been asked for a DIP version and this is basically the latest SMD version with swapped parts and a bigger PCB. Ordered at JLCPCB in red.
![](https://cdn.hackaday.io/images/6264831578079982990.png)
![](https://cdn.hackaday.io/images/3337521578079983790.png)
ToDo:
check if C2 needs to be a 10th of current value
![](https://cdn.hackaday.io/images/4030851581549920607.png)
A project log for zynthia - sequencer synthesizer
using a 40106, 4051 and a 4029 to make some noise, following the Logic Noise series on the blog
ToDo:
I liked the components layed in 45 degrees. My OCD dissgees, though!
not sure what made me do that :D
The board is cool the way it is! If you're ever going to redesign this board bend the ICs instead of straighten the discrete components, lol!
