I have been off this project for many months, maybe even a year but I got motivation to complete it. I bought a house and have a nice full size basement to incoporate this project into. Going to be sick.
- solenoid portion almost complete. I blew up a 24v dc power supply which hindered my progress.
- Recepticle box is almost complete. The hardware is having a bug with change in power to recepticles. Have to solve this.
- The Web API has been created. The Python code is in the works now. Simple commands to the two boxes work, but a database is needed to keep track of hardware status and settings.
- Admin features are being created first on the API side and HTML. This will enable me to create everything for the components instead of hardcoding and rewriting dymanic settings.
- When the above task are finished, I will rebuild the sensors unit and add the features into the UI.
I had a touchscreen loading a kiosk version before i quite the project. During the time cat knocked it off table and cracked it. I plan on purchasing an adafruit 7" to try it. Many changes to the Debian OS since last worked on this. Things should be easier to setup the touchscreen again, was a pain the ass first time I did it and was unstable.
** two new pictures have been uploaded showing a little of the project.
Joey Pongallo
