Already it has lasted 9 days constantly on.... Not many (actually any) flashlights I know of last that long, with so much brightness. So even now the project is a success.
Today I read 2.7v and .17 amps. The flashlight is still bright enough to light up a room pretty well and very usable as a flashlight. Brightness is now on par or better than my old incandescent 6v flashlight with fresh batteries. The onboard volt meter no longer registers(needs 3v). So tonight I will turn it off to see if it "recovers" like most say. My prediction will be that the voltage recovers, but the amps will still be weak.
Again no charging!
David Thomas
