Reading an old project's chip for backup before repurposing the chip...
READING the flash into an ihex file: AVR-Dude crashes with:
*** Error in `avrdude': free(): invalid next size (normal): 0x09323798 ***Aborted
- Linux x86-32bit
- ATmega8515
- Tried later with ATtiny861, same problem. (also with eeprom-read)
- avr-dude v6.1
- Tried later with v6.3, same problem.
- usb-tiny-isp v1.04 (this is the version that comes from adafruit)
- Tried later with FT2232H-based programmer, NO PROBLEM.
- v1.07 has been tried with same problem at second link, below
The file is written and appears to be correct.
VERY LITTLE info 'round the web about this error-message...
I think, mostly, due to the fact that the message isn't coming from avrdude, but from glibc(?)... most OS's probably don't actually print-out an error-message when free() is given an invalid address.
Here's what I've found:
http://www.avrfreaks.net/forum/error-avrdude-free-invalid-next-size-normal-0x000000000112c720
https://bugs.launchpad.net/ubuntu/+source/avrdude/+bug/1400185
http://www.mikrocontroller.net/attachment/301320/avrdude_crash.txt
http://savannah.nongnu.org/bugs/?41292 (not a usb-tiny-isp)
Otherwise, search-fu is failing me...
Again, from what I can tell, I think this "bug" is probably more-existant than these results, but I don't know what to search for, because, again, most OS's probably don't even report an error, and the file *is* created, so basically it *looks* like the program's exitting normally.
I've done a tiny bit of debugging (within my skillset) and determined
that my encounter with this error appears to occur within avrpart.c:
"avr_free_mem() -> m->buf = 0x9323798"
(or maybe it was already freed?)
As it stands, since I have an FT2232H-based programmer, I'll probably be using that, for now.
There's a new bug-submission, let's see what they've got to say :)
