Saturday well spent. Now I have all components in, nets routed, and passing DRC.
Still needs some tweaking. At minimum the silkscreen needs to be improved. But I'm generally pretty happy how this turned out so far, especially how everything mostly fit to the size I wanted even if it was completely arbitrary. I might even be able to shave a mm or two from the width.
