Probably going to connect the remaining bizarro signals (DCD/DTR/DSR/RI) to GPIO and figure out them later.
ESP-12F pins: 7 GPIO13 UART0_CTS 16 GPIO15 UART0_RTS 21 RXD UART0_RXD 22 TXD UART0_TXD DB-9 / | ESP12 | Signal | Direction | Description 200LX | | | | -------+---------+----------+---------------+---------------------------- 1 | ? | DCD | Modem -> PC | Data Carrier Detect 2 | 22 | RxD | Modem -> PC | Received Data (by DTE) 3 | 21 | TxD | PC -> Modem | Transmitted Data (by DTE) 4 | ? | DTR | PC -> Modem | Data Terminal Ready 5 | 15 | GND | Common | Signal Ground 6 | ? | DSR | Modem -> PC | Data Set Ready 7 | 16 | RTS | PC -> Modem | Request To Send 8 | 7 | CTS | Modem -> PC | Clear To Send 9 | ? | RI | Modem -> PC | Ring Indicator 10 | | prot.GND | Common | Shield
