I wanted a bedroom button to turn on the lights, one that was easy to just roll over and hit in the dark.
Without fumbling with a chain or column switch or such.
The box was purchased at HobbyLobby, the switches are big arcade buttons.
The steel slabs either side of the mechanism give the box a sense of weight and prevent it from sliding around on the tabletop, and the lithium battery will last decades.
