Design & functional considerations
04/21/2015 at 20:23 • 0 commentsMentioned below are key factors and constraints that will impact product components and overall design:
- board should have dimensions of 24x32mm and be compatible with the cheap, sub $10, eBay sourced nRF51822 board (it is a variation of Core51822 with additional quartz). This board provides BLE capability, ARM Cortex M0 CPU and some storage.
- the footprint of 9DOF board, nRF51822 and battery all stacked together should not exceed nRF51822's dimensions
- it should be super power efficient. Hence, every sourced component must be selected against this criterion
- Important part of the device is its storage capability. FLASH chip should take care of permanent storage. Minimum 16MB
- In addition to flash, FRAM chip will be used. This is a very fast nonvolatile memory and does not have limit of repeated writes, thus will ideally suit as a counter storage or buffer memory
- always-on accelerometer chip for low-precision measurements
- 9DOF multi chip module for precise motion detection
- 3.7V Li-Po battery with small footprint
Nice to have:
- SPI expansion socket to include other sensors (ex. barometer )
- for visual feedback a single-colour LED
- for tactile feedback a vibration motor
- button will be used for input
so .... Phase 1 - DONE
