The right rear leg quit--I figured a motor was cooked, but the problem turned out to be a stripped out plastic servo horn (note the bits of black plastic on the table).
![](https://cdn.hackaday.io/images/6747531521227784233.jpg)
I pulled the leg off to remove the old plastic horn.
![](https://cdn.hackaday.io/images/8737561521227857039.jpg)
The new aluminum horn fits the servo motor, but it's a bit dicey attaching the new horn to the 3d printed leg joint. It kind of works, but I'll have to redesign the joint and rework all the legs.
![](https://cdn.hackaday.io/images/1669011521227979963.jpg)
Changing two of these servo horns allowed enough control that I could attempt a sitting position.
