On February 27, the first attempt at standing was made. A couple of the joints couldn't take full speed movement--we learn by trying!
To attempt the first standing test, I needed to determine the servo angles for each motor. Below is the schematic for the system.
With the mechanism suspended, I determined the servo angles for each servo.
The numbers I retrieved are:
I applied those in an Arduino sketch (found in files on this project).
Two joints couldn't take the stress (I went full speed on the servos, kind of a worst case situation).
I'll have to redesign and install joints--then full torque ahead!
