Breakout board set
This is set of small breakout board I use to fill up space on multipanel boards
When ordering bigger multipanel boards, I often have unused space on those. I decided to make set of small breakout boards to fill up corners of those boards with something useful.
Yes, one can buy those breakout board cheaply from china, but using wasted board real estate is for free.
https://github.com/jaromir-sukuba/bbset
View all 2 project logs
FernandoElliot023 wrote 05/27/2023 at 07:05 • point
I am interested in buying a maintenance-free home. Can you help? I found this article on it but is it correct: https://mybakersfieldrealtor.com/real-estate-blog/interested-in-buying-a-maintenance-free-home/
phenexel wrote 05/09/2021 at 13:00 • point
I like your project idea. I'm working for a real estate mapping program and I want to embed your project with my site page of litchfield park az real estate .
Alexander Stepanov wrote 05/05/2017 at 19:35 • point
Panelized version will be helpfull.
Jarrett wrote 05/04/2015 at 16:39 • point
Fyi a quick-and-dirty Altium conversion is here: https://github.com/JarrettR/PCBs/tree/master/breakout
They fail DRC, but dirtypcbs didn't seem to have a problem with them, and they work fine.
jaromir.sukuba wrote 05/04/2015 at 18:29 • point
Awesome, thank you.
Mike Szczys wrote 03/21/2014 at 20:31 • point
Actually, you can easily embed your photos in the project description, logs, or instructions. The main project photo album is the only place that has a limit.
jaromir.sukuba wrote 03/21/2014 at 20:41 • point
This was my first project here on HaD projects. In the meantime I figured it out (ahem, actaully, I read that manual, everyone should do that at first place, you know). Thank you anyway.
