This is my first project here on hackaday.io. It's not very sophisticated, but I want to document it here nonetheless.
The basic idea is to have a night light in the hallway which is only turned on when somebody actually is in there. I want to use a PIR sensor for motion sensing and a LED strip as the light source. I don't want it to turn on the LEDs during the day so I want to use a RTC module for timekeeping.
Ana
Hulk
Nathan Peterson
OK, of course it depends. The place I needed the light was just at the door of the garden house. I needed an energy saving light to find the keyhole, which should go out when I leave and not drain the batteries of the solar power system. I have a RGBW LED strip there also, but not with PIR control. So for me PIR control is nice for illumination purposes, I don't want it for light effects.
You know that there are cheap (~8$) ESP8266 5 channel (RGB+W+WW) WiFi LED controllers on AliExpress? Which of course could be reflashed, if you want to do your own firmware. I don't have the SKU at hand, but it looks like a black plastic box (8*4*2,3cm) with green screw terminals, if you want to look for it.
