You may be wondering why there are green squiggles inderneath the #includes - it's very simple: The includePath in the c_cpp_properties.json is not fully populated with the links to the other header files.
The one in PlatformIO has all those. My next plan is to fill in the remaining blanks using some hints from the json file generated by the PlatformIO.
