SerialPlot v0.3 is released. Now you can install it on Windows. Note that we also have a Debian package that you can install on Debian/Ubuntu based Linux distributions! Only 64 bits versions though. I may look into generating 32bits packages if requested.
- Windows setup: serialplot-0.3.0-win64.exe
- Debian package: serialplot_0.3.0_amd64.deb
Most of the changes are small. Here is some of them:
- Save data to CSV file (File Menu -> Export CSV)
- Little/Big Endiann selection
- sample per second counter
- Ctrl-Q shortcut to close application
- Better error message reporting + "Log" tab for errors and warnings
- Added tooltips to GUI parts
- Demo mode indicator
- Fix port options not applied when opening
- Fix demo mode not pausing
