SerialPlot v0.11 release
A project log for SerialPlot - Realtime Plotting Software
Small and simple software for plotting data from serial port
hasan-yavuz-zderyaHasan Yavuz Ă–zderya • 09/14/2020 at 11:12•1 Comment
Well, it's been a while.
But I decided to finally put together a new release. There aren't any big news or changes. To be honest what pushed me to finally create a new release is that I forgot to move the "downloads' section from the bitbucket before they axed the mercurial repositories and as a result got a lot of mails/comments from people around to world. Sorry.
Here are some changes that come in v0.11:
Download links:
Linux AppImage (Ubuntu Trusty based, should work on anything newer):
https://serialplot.ozderya.net/downloads/serialplot-v0.11.0-x86_64.AppImage
Windows 32 bit (should work fine on 64 bit windows):
https://serialplot.ozderya.net/downloads/serialplot-0.11.0-win32.exe
Important: I didn't have time to test either of these images. Please let me know if you have any problems with them.
djhnsn wrote 11/09/2020 at 03:49 • point
I can't use the linux app image because I am running it on an ARM device. I built it, and it launched. My question is, how do I launch it again? If I navigate to the build directory and make run, it launches, but is there any file I can launch from a shortcut or terminal? I tried building an appimage, but it didn't work.
