I'm building a board for the ESP8266 - 07 where i connect things like: a RGB-LED Strip, Relay Modules vor mains power switchting, photosensor for checking this power, multiple LED lightings i use in my room. All of it controlled by an iOS app i wrote for this application.
Hi, I am working on the same type of project using, ESP 12E board but still not able to decide to do the coding in lua or Arduino IDE. I think Arduino IDE is better.
so did you learn the lua or still using arduino IDE in conjuction with Lua to make this happen .
