After some traveling for work I finally was able to order some parts. The Arduino UNO I already had but the Adafruit GPS logger shield I did not. This will cover me in two spots: The GPS signal, and the logging capability with the SD card reader.
The screen is a 128x64 liquid crystal display that will cover both the size and back lighting that I want.
I've been able to grab a pretty cheap and simple temperature sensor for liquids, as well as a general environmental temp/humidity sensor for the air.
The biggest problem I am having right now is being able to afford a pH or O2 sensor (not a great excuse, but it is the unfortunate truth). I have been in contact with someone who works on gas sensors in the hops to at least borrow one for a proof of concept.
Now to get the rest of a few things I've forgotten and the build the proof of concept!
