Purchased on Ebay a nice extruded aluminum enclosure, and mounted the (also ebay) ISOTEMP OCXO (10MHz). The mounting is free-floating: simply foam surrounding the crystal - tight enough for it to not shift or move around. Foam is glued to the enclosure with Gorilla PU style glue.
MoonLanding
