I replaced the inductors in the Robot Shop wire following kit with the following:
Murata 10 mH ±10% Bobbin Inductor, Max SRF:200kHz, Q:48, 600mA Idc, 2.294Ω Rdc 1400
and swapped out the 22nF capacitor with one of 2.2nF. The results were much more uniform!
The new inductors have a lot less resistance and should be much more sensitive and be able to pick up the wire from a greater distance away from it. Maximum distance with reception was measured as being 300mm so I positioned the inductor bobbins at 150mm to get nice reliable results:
The screenshot below shows the wire positioned about 30mm to one side of centre:
