I wired it all up and did the USB data splice so the lapdock would recognize the RPI, but it won't boot. When I push power on the lapdock, the RPI turns on for a bit like it's starting up, then it turns off for about 30 seconds, and then the lights on both it and the lapdock flash as if something is happening, but then it all turns off. I edited the config.txt file for the RPi to have suitable parameters but I don't know why it won't start up.
