Soldered together the latest revision this afternoon (number 7!), and thought I'd experiment with my GoPro's timelapse mode.
A project log for S1-AU Mk1: a 4-bit arithmetic unit
The S1-AU Mk1 is a 4-bit arithmetic unit, designed to help you explore the guts of computing.
