Hackaday.io Hackaday.io
Sign up Log in
Arduino, mqtt, web socket, home automation
Arduino, mqtt, web socket, building blocks for home automation.
Control led manually and remotely from a webpage and retrieve sensor info
liviubogdanioanliviubogdanioan
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
9.9k views
5 comments
10.3k followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 2
    • View all
  • Discussion 5
View Gallery
9.9k
5
10.3k
24
Team (1)
  • liviubogdanioanliviubogdanioan
Join this project's team
  • The excellent post for me
ongoing project
arduino node.js mqtt web socket mosquitto
Related lists
Home Automation
Relax in your home in the cloud. We've got it all under control
Proyectos interesantes
Ideas geniales para pasar el momentos gratos con la tecnología
Maybe
Curious projects that may fit future lessons.
This project was created on 03/18/2014 and last updated 2 years ago.
Description
Control led manually and remotely from a webpage and retrieve sensor information.
Creating a dashboard for control
Overview of the project it is here:
https://houseit.es/arduino-mqtt-web-socket-home-automation/
Components
  • 1 × ardino mega
  • 1 × cubietruck Server with linux node.js mosquitto
  • 1 × Ethernet shild
  • 1 × DHT11 temp sensor
  • 2 × led Fiber Optics / Emitters
Build Instructions
Collapse
  • 1
    Step 1
    Here is the part 1 of the project the arduino part.
    http://houseit.es/part1-arduino-mqtt-web-socket-home-automation/
  • 2
    Step 2
    This is part 2 of the project theserver side.
    http://houseit.es/part-2-arduino-home-automation/
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
midnightcow wrote 07/06/2015 at 04:51 • point
Hi, liviubogdanioan!
Your project is very cool!!. I'm a wiznet engineer. Will I introduce your project on wiznet museum site(http://wiznetmuseum.com/). WIZnet has launched W7500 CortexM0 with TCP/IP and WIZwiki_W7500 platform at May, 2015. If you interested on new wiznet products, You can request to free sample on http://wiznetian.com/sample-request/.
Thank you in advance.
Dragos.m.constantin wrote 03/02/2015 at 11:52 • point
Salut, Merci pt. raspuns.  Am citit si prima parte a acestui proiect inainte de a posta primul meu comentariu, se pare ca este la mine o problema cu libraria mqtt pub/sub, Arduino nu compileaza. Adresa mea de email este: dragos.m.constantin@gmail.com
Dragos.m.constantin wrote 03/01/2015 at 12:31 • point
Salut,
Poți sa ma ajuți te rog cu mai multe info. despre proiectul tau? Încerc de mai bine de 4 luni diverse variante de comunicare intre arduino si www dar fara nici un rezultat concret.
Ceea ce as vrea sa fac este sa realizez o comunicare in timp real intre arduino, server si client.... nu reușesc, am încercat diverse combinații găsite pe net cu nodejs, websockets, Apache, etc. De fiecare data trebuie sa o iei de la capăt, sa înveți un soft nou si sa te blochezi undeva.
Poți sa imi dai te rog un exemplu cu 2 butoane (gen flip, slider), 2 butoane impuls care la apăsare sa schimbe textul sau culoarea si  care sa reacționeze in timp real la utilizarea mai multor clienți? Adică daca unul din clienți aprinde un led, ceilalți clienți sa vadă butonul modificandu-si starea din Off in on si sa poate fi oprit de oricărui din clienți? In același timp acționând un buton pe breadboard sa se întâmple același lucru?
Merci abticipat
liviubogdanioan wrote 03/01/2015 at 20:50 • point
da sigur ca te pot ajuta. Dar cum ceea ce imi descri are nevoie de un pic de munca iti propun sa intri pe situl meu, si citeste prima parte a proiectului unde e descris ce folosesc. Lasa un comentariu cu mailul tau si propun sa continuam pe mail e mai simplu si mai usor.
Eric Tsai wrote 07/20/2014 at 07:11 • point
Hi, thanks for the skull! I also tried to use Node.js and MQTT to talk to Arduinos. Wish you the best.
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Arduino, mqtt, web socket, home automation", please tell us the reason.
Send message
Remove Member
