• Quickie Proto
    Moley Hackeral • 05/08/2015 at 03:58 • 0 comments
    I have finally started doing something with this. I have hooked up the servo to the mini, and right now, I am interfacing directly via serial. It is probably the worlds simplest demo at this point. Take a number in via serial and map it to the servo range.
    To keep things interesting I printed of a gauge face and mounted it in the face of an old cd case.
