ELL-i RasPoE IndieGoGo campaign is LIVE
So, we finally decided on a name: RasPoE
We also opened the IGG crowdsurfing campaign so as to make a run of the boards for us, you, everybody and their dogs. And cats.
This far we have tested the board against 802.3af and 802.3at PSE units from Juniper, Cisco, Zyxel, D-Link, Phi Hong and several other vendors. Integrated PSE is architecturally more pretty but midspan PSE works just as fine.
Also, our boards do protect the Raspberry Pi network chip from frying when unplugging the cable while the system is running. Cutting the cable in mid-run is also okay, but I forgot to take a video of it.
