The tricky setup issue
was due to the com port number that a pc assigns to an arduino (like
the one in the brain box ). The processing app for eyedrivomatic
needs to know that number. Each user had to discover his own com port
number, and manually alter the code for the app. Simple for a geek.
Hard indeed for a normal person – daunting even.
That problem
has now disappeared, thanks to our brand new Eyedrivomatic Port
Finder app. Written by W. A. Smith, and modified by Steve Thomas,
port finder finds out your com port number, and stores it in a config
file on your pc – ready for the main eyedrivomatic app to use.
Its
brilliantly simple. You run port finder once only, and then the main
eyedrivomatic app runs perfectly. Simple.
The new port finder app
is up our Github repository, along with the modified main
eyedrivomatic app.
Its just the Grid2 issue to deal with now.
Give me a few more weeks, and eyedrivomatic will work on any pc, with
or without Grid2, simply!
