3 way PCB pad
Connect a pads in three different ways.
I believe somebody else also made something similar. It's sometimes simply a need. I tried to make it like peace sign but i couldn't make it in eagle as easy as this. I hope someone will find it useful.
I found it useful on a board where i want to have an option to:
1. have input button which i connect to another side of a PCB (just passing a line)
2. Redirect the input button to a MCU
3. Use output terminal as input and redirect the signal to a MCU
.. I don't know if you could understand but.. i believe just by looking at it, it's clear what it can be used for.
jumper-3way.lbr
Eagle Lib
lbr - 8.83 kB - 02/15/2018 at 01:19
Download
