I know I suck at soldering but heres a pic of the relay module that I soldered. It was very tiresome job to solder all the components together.
A project log for Low Cost Wireless Home Automation and Security
This is an IoT based wireless Home Automation and Security System
what kind of wires are you suggesting?? I also found that some single core wires are very brittle.... they tend to break easily.... its better if you can give e some links to the wires you are talking about.
I recommend to use thinner wires, it makes soldering easier. I also use silver coated wires for things like power buses etc.
