Automated supply of water to plants using Arduino Uno, Soil moisture sensor and Flow sensor
Tjeck out this ! https://hackaday.io/project/6995-icndy
When you get it online, it could be used with our UI. Just need do integrate some kind of Key Gen for users to register devises.
want make it an IoT-Device, that you can monitor and controll it from the internet ?
write me: info@euerdesign.de
An ESP8266. You can get rid of the arduino completely (and using the Arduino IDE for the ESP8266 [https://github.com/esp8266/Arduino] you can still use your arduino code).
You can download it here- http://jmoonmaker.space/public/automatic-plant-watering-system
Click on button just above the images and use Social Pay to download code.
Links for the roborium items have changed:
Micro Plastic Submersible Pump
https://roborium.com/micro-plastic-submersible-pump
Flow Sensor
https://roborium.com/flow-sensor
Soil Moisture Sensorhttps://roborium.com/soil-moisture-sensor
