It works and is now battery powered using two 7.2V RC Battery NiMH. Now looking for a portable small smoke source. Yes I could use a smoke machine but it's not very portable. Smoke in a can is only available from the UK and the supplier will not ship to Australia? Vortex cannons don't need smoke but it does look good if you can.
this is an old project, so I'm not sure if its still being considered, but would some sort of Vape or cold gas be a reasonable smoke source?
