Project renaming
A project log for Jsoknit 2015
Simple embedded software function definition JSON framework.
daniel-sikarDaniel Sikar 08/15/2015 at 14:190 Comments
After some mulling I decided to change the name from Weblino to JASONette Interface. Weblino is an attempt to mix Web and Arduino to convey an idea of distributed embedded systems but since JSON is central to the project and the actual transport, so to speak, as well as the embedded platforms, are secondary, I figured the new name would be more descriptive.
