Weekend's TODO list
A project log for Jsoknit 2015
Simple embedded software function definition JSON framework.
daniel-sikarDaniel Sikar • 08/21/2015 at 17:24•0 Comments
1. Merge Atmega 328, MAX31855, BT0415, opto-coupler and solid state relay into a single pcb. NB Include programming header and mini USB female connector. OK
In the end and for the time being decided against the programming header and mini USB female connector, opting instead for a 28 DIL socket to house the Atmega328, which will be pre-programmed.
Fig. 1 JASONette Interface compatible circuit v0.1
