For people who didn't notice my little demo on Hackaday Superconference during last weekend - this is 5-minute video:
Source code of the demo: https://gitlab.com/shaos/xorlib/blob/master/examples/demo2016.c
This is a collection of some XORLib examples that I created since April 2015 plus couple new pieces of code combined into a single C-file (also 2 additional data files are required and of course XORLib - everything is there on GitLab). Enjoy ;)
UPDATE: Prebuilt binary in HEX form is available on GitLab:
https://gitlab.com/shaos/xorlib/tree/master/builds/demo2016-PIC32MX170F256B-O1
SHAOS
The last sequence... Is it what I think it is ?
and what is it? :)
If you are talking about rotating planet (aka "Moon") then I simply reused animation from my University Project from 1995:
I recompressed it to new format with 7 colors + transparency and simple RLE scheme (displayed with dithering when 2 vertical pixels represent dithered color).
Oh that part was prerecorded ?
I thought it was easy to recompute it on the fly, I had seen some code in the '95s
The last sequence : I meant the B&W "snow"
Unfortunately I lost all my sources for that demo'95 so I used pre-recorded sequence that I re-compressed with lower resolution and smaller number of shades. Anyway I remember that it was heavy computation - terrain was computed for a few days with save points on 386DX40 machine...
About squares - it was simply random squares for widescreen TV with unproportional monochrome resolution 640x200 (so programmatically they are not squares at all):
for(y=0;y<200;y++)
memset(xodirectline(y),0,80);
t1 = xoseconds();
t2 = t1 + 32;
while(t1 <= t2)
int x1 = (rand()%90)*7+5;
int y1 = (rand()%50)*4+1;
#if 0
int c = rand()%3;
#else
int c = ((rand()&63)>(t2-t1))?0:1;
#endif
if(c==2) xorect(x1,y1,6,3,1);
else
xoline(x1,y1,x1+5,y1,c);
xoline(x1,y1+1,x1+5,y1+1,c);
xoline(x1,y1+2,x1+5,y1+2,c);
t1 = xoseconds();
I don't get your xo code but ok, it's not what I thought. I was fooled :-D
xo... is for XORLib functions:
xodirectline(int N) returns pointer to videobuffer of Nth line of the screen
xoseconds() returns value of counter of seconds
xorect(X1,Y1,X2,Y2,C) draws rectangular with color C
xoline(X1,Y1,X2,Y2,C) draws line with color C
Demo is in 640x200 monochrome mode with color burst enabled, so TV will see color in most 4-pixel combinations with effective resolution 160x200 pixels, but 1st scene (with my face avatar) is actually 160x400 because I used interlaced trick (works on most modern NTSC TVs) - quickly switching 2 images every frame to force TV to build full frame with better resolution - that's why it looks better than expected :)
WOW
