A different idea is to add a small solar panel/cell with some changes:
- Adding a small solar panel which mounts on top of the microcontroller and other circuitry on the top side. Some options are the following:
- A polycrystalline small cell measuring 23mm * 20mm * 3.2mm like these
- A high efficiency monocrystalline solar cell available on digikey measuring 22mm * 7mm * 1.8mm
- A rechargeable lithium ion battery needs to be used such as the following:
- The solar panel provides 0.6V (max) at 50mA. A boost converter is needed to get this voltage up to charge the battery
- All the circuitry needs to be on the top side. No double sided load
- The solar panel (especially the 22mm * 7mm one) needs to be somehow mounted on the top-side circuitry
Vikas V
